Activity › Forums › Apple Final Cut Pro Legacy › FCP X suddenly failing to upload directly to YouTube.
  • FCP X suddenly failing to upload directly to YouTube.
    Posted by Erik Blair on December 30, 2015 at 9:22 pm
    So I’ve suddenly got a problem with Final Cut Pro X 10.0.9 failing consistently in any attempt to share directly to YouTube.
    Up until about a week ago, I had been having no problems with any upload. I would finish editing in the timeline, share the file, it would create the .mov file and then upload it to my YouTube channel.
    About a week ago, however, I suddenly began to have a consistent error with every single upload. Now if I attempt to share directly to YouTube and turn on the Background Tasks window, I can see that at 50% the .mov file gets created as per normal. Then the percentage gets all the way to 99% before it then gives me an error message saying that the share to YouTube has failed. When I then check YouTube, there is NO indication that it has actually attempted any sort of upload at all. There is no aborted upload, nothing.
    I made no changes that I am aware of in my FCP preferences or workflow. Can anyone help me figure out what I can try or change or check to get the upload process working again? Yes, I CAN upload the .mov file to YouTube directly–but that equates into changing the entire workflow timing on the channel (as I often need to be uploading overnight, which made the one step render and upload workflow work very well for my channel).
    I am on a Mac, OS X 10.9.5. I don’t know what other info people might need for this one. But any help would be REALLY appreciated, because since I didn’t change anything, I don’t know where to even attempt to fix it. (And I know it MIGHT be over on YouTube’s side, even).
    Erik Blair replied 10 years, 9 months ago 2 Members · 2 Replies
  • Nick Meyers
    December 30, 2015 at 9:37 pm
    this is an FCPX question.
    it needs to be posted in the FCPX Techniques FOrum
    this forum is for FCP7 and under
  • Erik Blair
    December 31, 2015 at 12:24 am
    My apologies! Multiple Google searches came up as this being the correct forum! I’ll put it in the right place.
