Activity Forums Apple Final Cut Pro FCP X shows “there was a problem connecting to the server “time capsule” , at startup
  • FCP X shows “there was a problem connecting to the server “time capsule” , at startup
    Posted by Manuel Wenger on June 27, 2012 at 8:06 pm
    i get this message after FCP X started. And no matter how often i click OK, it will come again and again.
    I tried to turn off time machine, reset my time capsule, enabled/disabled filesharing on the capsule, nothing helped and i´m going crazy !!
    With this message popping up every 1-2 minutes FCP X is useless to me.
    Anybody ever had that problem ?
    Running 10.7.4. on MBP retina, but Problem was also on my old MBP 15″ early 2009 running 10.7.4
    thanks
    Manuel
    DP / DIT
    Munich – Germany
    Julie Guèvremont replied 13 years, 10 months ago 3 Members · 3 Replies
  • Bill Davis
    June 28, 2012 at 6:32 pm
    Clearly, you’ve got a link to some asset that the program thinks is located on “Time Capsule” – but it can’t find it.
    Try trashing your Preferences. That sometimes clears up this kind of location based issue.
    (Theres a nice free or cheap utility called Preference (or Preferences) Manager (can’t remember precisely) that does this easily without you having to dig around in your system folders to find what to dump.
    Drop back and let us know if that helps.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • Manuel Wenger
    June 28, 2012 at 9:41 pm
    Hi Bill, thanks for your advice.
    Finally today i got the issue solved with the help of Apple Support.
    It was a setting in the User Preferencesm and the problematic file was
    com.apple.iApps.plist
    it took some time to locate it but now i´m fine and FCP X runs fine.
    thanks for your help anyway, and i hope this info can help if someone else is running into that problem
    Manuel Wenger
    DOP / DIT / Digital Colorist
    Munich – Germany
  • Julie Guèvremont
    October 15, 2012 at 11:57 am
    Hi Manuel,
    I got exactly the same problem at startut, trying to use FCP 7 that was just installed on the computer.
    Could you give me a few details about how you saved the problem? Where was the file com.apple.iApps.plist located and did you simply erase it?
    Many thanks,
    Anna
