Activity › Forums › Apple Final Cut Pro › FCP X output via Kona LHi
  • FCP X output via Kona LHi
    Posted by Nigel Thompson on February 7, 2014 at 6:02 pm
    Recently started using FCP X 10.1 and installed new firmware for my LHi on Mavericks.
    Im getting output via the LHi just fine ….(HDMI) except during playback the resolution drops to a preview resolution.
    I have the AJA software set to 1080p 23.98 and im seeing the image quality drop everytime i hit play in FCPX ….
    Is there a step im missing in FCP ?
    I cant say if the SDI out is doing the same because i have not been able to hook it up to a monitor yet.
    High End, Production & Post Production
    in the Caribbean
    http://www.bistt.com
    Bret Williams replied 12 years, 7 months ago 3 Members · 4 Replies
  • Bret Williams
    February 7, 2014 at 8:14 pm
    Are you working with fields? My BMD Express has a control panel setting to play 1 field or two when paused. It’s called “remove field jitter when video is paused.”
  • Jeremy Garchow
    February 7, 2014 at 8:50 pm
    Make sure this is checked(image):
    Jeremy
  • Nigel Thompson
    February 8, 2014 at 12:44 am
    Thanks VERY much Jeremy …… that did he trick
    in the Caribbean
  • Bret Williams
    February 8, 2014 at 5:55 am
    Doh, I read it backward. Glad you got it.
