Activity › Forums › Apple Final Cut Pro › FCP X Generator: BG Just Strobe it!
  • FCP X Generator: BG Just Strobe it!
    Posted by Brendan Gibbons on July 26, 2011 at 11:40 am
    A simple FCP X GENERATOR preset, using motion’s strobe behaviour to give you access to the strobing effect in FCP X
    This effect has been done as a generator, because I have found a way to publish the retiming behaviours to FCP using the EFFECT option, but it crashes FCP on demand every time.
    Though Generators are not an ideal solution it appears to work.
    Use at your own risk though because according to apple these retiming behaviours can’t be published to FCP X. Wrong!
    Apple 0 v Brendan 1
    – Select the Generator tab to access published parameters
    – Click image well to select your source clip
    – Strobe frame duration controls.
    – Optional luminance flicker controls to enhance the strobe effect
    Screenshot:
    Drop the folder “BG Just Strobe it!” inside this zip into the following directory:
    Movies / Motion Templates / Generators / BG Generators /
    Full Install instructions included in README inside the zip file.
    Cheers,
    BG
    Shawn Strong replied 14 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
  • Tony Brittan
    July 26, 2011 at 12:01 pm
    So…is this like the Blink filter from FCP past?
  • Brendan Gibbons
    July 26, 2011 at 12:11 pm
    Not like the blink filter this one.
    You tell it how many frames to hold the motion.
    Some call it a frame update.
    Set it 5, it holds frame 1 for 5frames, then it holds frame 6 for 5 frames, then frame 11 for 5 frames….etc
    Cheers,
    Brendan
  • Brendan Gibbons
    July 26, 2011 at 12:22 pm
    This filter preset from a few days ago does the same as what the blink filter in FCP 7 does.
    https://f1.creativecow.net/2655/2655
    Stack up 2 layers of video, apply preset to top layer, and adjust rate to suit.
    Cheers,
    BG
  • Tony Brittan
    July 26, 2011 at 12:25 pm
    Oh cool! You guys have done such a good job of turning these things out I’ve had a hard time keeping up 🙂 Thanks or the heads up!
    Tony Britan
  • Eli Hollander
    July 27, 2011 at 6:21 am
    Really useful… At the risk of being repetitious, thank you!!
  • Brendan Gibbons
    July 27, 2011 at 6:46 am
    Glad it was of use to you 🙂
    As you are probably aware, drop zones in generators seem to be a bit problematic at times.
    I have noticed quite often when you select the dropzone, and the box comes up prompting you to choose a source…it can freeze quite often.
    All together now … “Bring back ‘send to motion’ please”
    Cheers,
    BG
  • Joe Best
    February 1, 2012 at 8:22 am
    Hi, i donw loaded it but i cant use it. I past it on the clip and it inserts or replaces. I cant find the generator controls you speak of. Sorry to be such a novice but from the information in your pack i just cant find out how to apply this effect to aclip. I see it in generators but cant do anything with it. Could you explain how to use it and also show a screen shot of where you got your screen shot of the generator controls from. Thanks
  • Shawn Strong
    May 19, 2012 at 10:31 am
    how do you install this preset/effect?
