Activity Forums Apple Final Cut Pro FCP X Generator: BG Frame of Thought
  • FCP X Generator: BG Frame of Thought
    Posted by Brendan Gibbons on August 7, 2011 at 7:45 am
    BG: Generators in FCP X
    “BG Frame of Thought”
    This is an FCP X Generator.
    This is most likely the most simple preset you will come across. No really… It performs a Hold frame / Freeze frame on the frame of your choosing.
    Are you feeling as underwhelmed as I am? … Sorry I cannot dress it up any more than what it is 😉
    It’s not supposed to be able to be published to FCP but with a simple workaround it can be.
    – Choose your source footage
    – Choose your freeze frame
    Screenshots:
    Drop the folder inside this zip called BG Frame of Thought into the following directory:
    Movies / Motion Templates / Generators / BG Generators /
    Please refer to the README inside the zip file for full installation instructions.
    Cheers,
    BG
    Simon Ubsdell replied 15 years ago 3 Members · 10 Replies
  • 10 Replies
  • Alex Gollner
    August 12, 2011 at 6:57 pm
    Interesting copy protection method!
    That workaround is the kind of thing that will be fixed in the next revision. I think I’ll keep version 5.0 just in case.
    Alex
    ___________________________________________________
    Alexandre Gollner,
    Editor, Zone 2-North West, London
    alex4d on twitter, facebook, .wordpress.com & .com
  • Alex Gollner
    August 12, 2011 at 7:46 pm
    I have a request!
    Could you produce a version that publishes the Fit parameter?
    That would help people who want to choose which page of a PDF to show.
    Cheers,
    Alex
    Alexandre Gollner,
  • Brendan Gibbons
    August 12, 2011 at 8:47 pm
    Copy protection method?
    You’ve lost me.
    Although I have noticed that trying to edit any effects that have had re-timing behaviours parameters published can result in some quite instant crashes of Motion.
    Is that what you are referring to?
    Cheers,
    Brendan
  • Brendan Gibbons
    August 15, 2011 at 1:19 pm
    [Alex Gollner]
    That would help people who want to choose which page of a PDF to show.”
    Do you mean the Page Number slider?
    I tried that one out a few weeks back, but no matter what type (generator, effect or title) the page number parameter would never seem to pick up the PDF in the timeline of FCP X. The slider can be published, but it would not detect the number of pages in the pdf.
    Bizarrely it would work fine if you left a pdf inside the effect you published. Which is fine just as long you only use that same pdf over and over and over again 😉
    Cheers,
    BG
  • Simon Ubsdell
    August 15, 2011 at 4:21 pm
    Hey, loving your new avatar – great design!
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
  • Simon Ubsdell
    August 24, 2011 at 8:39 pm
    Any idea why retiming behaviors don’t wortk with Effects but do work with Generators? Not sure I can quite follow the logic of this …
    Simon Ubsdell
  • Brendan Gibbons
    August 25, 2011 at 9:18 am
    I did get it to work once, I say work…. I was able to publish it, but then applying the effect in fcpx caused an instance crash….
    Be good if things were a little more consistent.
    Cheers,
    BG
  • Simon Ubsdell
    August 25, 2011 at 11:38 am
    That’s a shame. (I can’t even get it to “accept” a Hold behavior a within Motion Effect project let alone publish it.)
    And it doesn’t really make sense that retiming shouldn’t be available within Effects, does it?
    Simon Ubsdell
  • Brendan Gibbons
    August 25, 2011 at 4:01 pm
    The way I stumbled upon to get retiming behaviors to attach inside a motion effect template, was to import any video clip, attach retiming behavior, make it a dropzone then clear the media from the dropzone.
    It then publishes fine, but apply the effect in X and you get an instant crash.
    I tried publishing it with a 1frame media clip hoping you could just clear the dropzone in x, but to no avail.
    Retiming behaviors being available in x would be helpful in soo many ways.
    Cheers,
    Bg
  • Simon Ubsdell
    August 25, 2011 at 4:56 pm
    Thanks for the explanation. I have to admire your considerable cunning in getting that far – too bad it didn’t work out!
    Simon Ubsdell
