Activity › Forums › Creative Community Conversations › FCP X – Export selection from timeline sequence
Posted by Ben Lithman on July 6, 2011 at 9:57 pmHas anyone figured out how to only export part of a sequence from their timeline in FCPX? In FCP 7 it was just a matter of setting in and out points in the relevant places in the timeline, and then exporting.
Doing the same in FCPX seams to lead to the whole sequence being exported regardless of the In and Out points.
Joady Weatherup replied 11 years, 10 months ago 18 Members · 31 Replies -
Greg Burke
July 6, 2011 at 10:03 pmyou have to send the whole seq to compressor 4 and set the in and outs in there.
I wear many hats.
http://www.gregburkepost.com -
Ben Lithman
July 6, 2011 at 10:07 pm“you have to send the whole seq to compressor 4 and set the in and outs in there”
That’s the only way?! That’s so so disappointing…
I have a massively long project and just wanted to send a few seconds to someone to preview. Seams nuts to have to export the whole project first. -
Steve Knattress
July 6, 2011 at 10:09 pmcut and paste the required section/range into a new project (=new sequence), then export from there?
Greg Burke
July 6, 2011 at 10:09 pmYou Dont have to export the whole Seq, Just Send it into Compressor 4, and select witch part you want Compressor to Export.
I wear many hats.
Dale Robinson
July 6, 2011 at 10:12 pm“I have a massively long project and just wanted to send a few seconds to someone to preview”
Copy & Paste the portion that you want into another sequence. Then export.
Lance Bachelder
July 6, 2011 at 10:15 pmAgreed – this is the same way FCP 7 works except you got to set your in/out on the FCP timeline – the whole project is always there in the preview window and in Compressor – not just the in/out portion.
Lance Bachelder
Southern California -
Noah Kadner
July 6, 2011 at 10:57 pmAnother way would be to select the entire timeline and make into a compound clip. Then trim that. I’d be cautious if it’s a huge project with tons of media though- might want to duplicate the project first just in case.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and GoPro HD Hero.
Matt Callac
July 6, 2011 at 11:03 pm[Noah Kadner] “Another way would be to select the entire timeline and make into a compound clip”
or select the section you want to export and compound clip it.
-mattyc
Craig Seeman
July 6, 2011 at 11:58 pm[Noah Kadner] “if it’s a huge project with tons of media though- might want to duplicate the project first just in case.”
Or go ahead and duplicate the project and chop off what you don’t want to export in the duplicated project.
James Carey
July 7, 2011 at 12:03 amGood lord, did you guys just read the advice you have given to what right now is so simple to do in FCP7. Are we to expect work around like this for all such simple tasks?
Jim Carey
Director of Video, Radical Entertainment
linkedin: https://ca.linkedin.com/in/jcarey256
mobygames: https://www.mobygames.com/developer/sheet/view/developerId,17212/
