Activity Forums Apple Final Cut Pro FCP X Adjustment Layer: BG What’s in the Broadcast Safe? (luma & Chroma fix)
  • FCP X Adjustment Layer: BG What’s in the Broadcast Safe? (luma & Chroma fix)
    Posted by Brendan Gibbons on September 14, 2011 at 9:26 am
    BG: Adjustment Layers in FCP X
    “BG What’s in the Broadcast Safe?”
    This is an FCP X “Adjustment Layer” made from a Motion title preset.
    This preset gives you a….unsurprisingly…A Broadcast Safe Filter.
    DOWNLOAD FCP X Adjustment Layer: BG What’s in the Broadcast Safe?
    I had already incorporated this into a previous filter, but it had a number of other different functions as well. So I wanted this in it’s own filter, so that it was as “light-weight” as possible.
    With a small bit of sneaky rigging in Motion, this preset gives you something that doesn’t come with the
    standard Broadcast Safe filter from Motion.
    The standard filter only gives you the choice between Luminance or Saturation as a fix method.
    This preset has been rigged so that the default fix method is both Luminance & Saturation at the same time.
    – Broadcast Safe activation
    – Pal or NTSC
    – Luminance, Saturation or Both as a fix method.
    – Piece of mind knowing your video is kept within broadcast goodness.
    An important note, or disclaimer if you like. A Broadcast Safe filter is not a magic fix. You should obviously be making sure your colour corrections are primarily within broadcast acceptable levels anyway – without the use of a Broadcast Safe filter.
    A Broadcast Safe filter can introduce unacceptable artefacts to your picture if you are asking it to do too much. You have been warned! 🙂
    Screenshots:
    Drop the folder inside this zip called BG What’s in the Broadcast Safe? into the following directory:
    Movies / Motion Templates / Titles / BG Adjustment Layers /
    Any questions, please do not hesitate to ask.
    Cheers,
    Brendan
    th**********@***il.com
    @HaHaBoomBoom
    Brendan Gibbons replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
