Activity › Forums › Apple Final Cut Pro › FCP X 10.3 – audio enhancements where are all the settings gone???
  • FCP X 10.3 – audio enhancements where are all the settings gone???
    Posted by Michael Paul on November 10, 2016 at 4:14 pm
    So audio enhancements used to have 3 settings: Loudness, fan/hum background noise removal and something I can’t remember any more. Where are those?
    All I find under Audio Enhancements is Audio Analysis and FIXED. I can’t seem to get into any of the options anymore. It’s as if it was locked down. No permission granted.
    So did Apple remove those features?
    I’ve used the loudness slider a lot to go OVER the +12 dB FCPX gives me when adjusting waveforms. So what do I do now? Premiere has add audio gain for example and I can add +X dB. I feel like if I have reached the magical 12 in FCPX for audio I am out of luck. Any idea? Thanks.
    Michael Smith replied 9 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • Lawrence Eaton
    November 10, 2016 at 5:25 pm
    With a flat design mode, things change just to keep u on our toes, Michael. Have a look at this image and it may help.
    https://f1.creativecow.net/10777/audio-enhancements-in-fcpx-103“>10777_screenshot20161110at12.17.58pm.png.zip
    Lawrence
  • Michael Paul
    November 10, 2016 at 8:24 pm
    Thanks a lot for this, Lawrence. This is exactly what I am searching for. How do I get there? Where did you click? I already hovered my mouse over areas hoping for something like “show” or expand and clicked around desperately. So could you kindly tell me where I have to click in order to get this menu? Thanks a lot
    It’s like the export settings. I click on share and in that bubble I only got like 4 export settings and I was like “Where is the rest? WHERE IS IT?” Until I scrolled my mouse wheel on accident while the mouse was still hovering over the export speech bubble and THEN all of a sudden a scroll graphic showed up on the right hand side. Confusing design. The scrolling bar should get displayed from the start or they should cut one icon off in half so that I know that this area is scrollable.
  • Lawrence Eaton
    November 10, 2016 at 9:39 pm
    Have a look at this video and see if it clarifies things for you, Michael.
    10781_audio.mp4.zip
    Lawrence
  • Michael Paul
    November 11, 2016 at 9:49 am
    Thanks a million for all the trouble and recording this. You are a great person!
  • Federico Betta
    December 6, 2016 at 3:56 pm
    Thank you a lot Lawrence for your video.
    But my layout has something strange.
    All is right on video tab, but Audio has not expandable button.
    Here a video 10853_fcpx10.3audioenhancements.flv.zip
    It is a big bug or I do something wrong?
    thank you for any advice.
    Federico
  • Federico Betta
    December 6, 2016 at 3:59 pm
    Sorry, my mistake.
    My clip was a multicam. So Audio enhancements is not possibile.
    I have to go to the originale clip to modify audio.
    Thanks anyway
  • Jacob Thompson
    January 25, 2017 at 11:57 pm
    Did you find an answer ti this? My inspector does not give the show option. It only allows the auto magic wand and that does a terrible job.
  • Michael Smith
    April 7, 2017 at 7:03 am
    This had me troubled as well.
    In my case when I detached audio (which I do a lot) the audio enhancements went away. Here’s how to get them back.
    At the bottom of the inspector window where the audio enhancements should be, there is a section called Audio Configuration.
    In mine there what looks like 3 tracks there but the top one is a configuration setting, not the actual track as it doesn’t have the little speaker icon next to it. Click on the actual track below that and the Audio Enhancements will return.
    Probably when that top ‘track’ is selected it’s actually selecting both of them and it can’t do an audio enhancement on both tracks when they’re not grouped. In my case they were from different mics (and one was turned off) so obviously they would have completely different needs. So it knows to not apply the same enhancements to these different tracks.
