Activity Forums DaVinci Resolve FCP X 10.0.3 XML import broken?
  • FCP X 10.0.3 XML import broken?
    Posted by David Battistella on February 2, 2012 at 4:32 pm
    Since installing 10.7.3 OSX LION
    Beta 8.2 Resolve lite
    FCPX 10.0.3
    It seems that XML import is broken.
    NO matter what sequences I send, I get a dialog box saying that it is V1.1 of the XML and then when I hit ok, I get a dialog box that says the XML does not contain a sequence.
    Any help appreciated.
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://vimeo.com/battistella
    David Battistella replied 14 years, 6 months ago 4 Members · 6 Replies
  • Ola Haldor voll
    February 2, 2012 at 4:39 pm
    If I recall correctly, the dialog says it’s XML 1.1 and that some things might not work.
    As far as I know, FCPXML 1.1 is new as of January 31 – DaVinci haven’t had any updates after that. In other words; I don’t find that weird at all.
  • David Battistella
    February 2, 2012 at 4:48 pm
    Here are the two dialogs…
    David
    Lord Herbert
  • Dwaine Maggart
    February 2, 2012 at 6:01 pm
    Resolve support of the new FCPX 10.0.3 XML format will require an updated version of Resolve. We hope to have that available soon.
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • David Battistella
    February 2, 2012 at 6:09 pm
    Amazing and thanks for the quick response.
    It’s really an elegant workflow.
    David
    Lord Herbert
  • Jacob Lanum
    February 3, 2012 at 4:16 am
    For now you can open the fcpxml file In text edit and simply change the text from 1.1 to 1.0 and it will import fine.
  • David Battistella
    February 5, 2012 at 5:47 pm
    It’s fixed in the latest beta!
    Thanks BMD Davinci team…
    David
    Lord Herbert
