Activity › Forums › Apple Final Cut Pro Legacy › FCP wont play in timeline
Posted by David Lendau on March 23, 2009 at 4:22 amHello
I am working on a project and i got the QT footage on the client drive it is
Vid Frame Size: 1024×576
FPS: 25
Video Codec: Uncompressed 8-Bit 4:2:2
Aspect Ration Square
Audio 48.000kHz 16 Bit Audio Codec 16-bit Big EndianIt wont play on FCP timeline, play good audio and video in the viewer but not on the timeline. i do have kona card what should i do the make it work.
Thank you
DavidDavid Lendau replied 17 years, 6 months ago 3 Members · 6 Replies -
David Roth weiss
March 23, 2009 at 6:23 am[david Lendau] “I am working on a project and i got the QT footage on the client drive”
That material you’re trying to edit is uncompressed HD, which cannot be played back off of anything less than a hard drive raid sub-system with at least five or six drives, and preferably eight.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Phil Balsdon
March 23, 2009 at 7:36 amLooks like PAL 16.9. (Anamorphic) SD.
Possibly originated from Digi Beta or SP Beta hence”Uncompressed 8 bit 4.2.2″.Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
https://www.steadi-onfilms.com.au/ -
David Roth weiss
March 23, 2009 at 8:32 amRight Phil, I missed the pixel dimensions. It’s 8bit uncompessed SD, but it still requires a raid.
David Roth Weiss
Director/Editor
David Lendau
March 23, 2009 at 5:45 pmBut it play great on the viewer , only when i put it on the timeline i get a red line “unrender” and even after i render it it is still playing as freez frame. had it been a need for the raid it wont ask for the media to be rendered no?
Thanks for your help
David Roth weiss
March 23, 2009 at 6:04 pm[david Lendau] “But it play great on the viewer , only when i put it on the timeline i get a red line “unrender” and even after i render it it is still playing as freez frame. had it been a need for the raid it wont ask for the media to be rendered no? “
David,
The red render line means one of the following two things:
1) Your sequence settings do not match your media.
2) Your system does not have the throughput necessary for play back your media in realtime without rendering.
My guess would be both of the above. Let me suggest that you watch the following tutorial and follow it to the letter when beginning any new project.
https://library.creativecow.net/articles/biscardi_walter/realtime_sequences.php
David Roth Weiss
Director/Editor
David Lendau
March 25, 2009 at 12:21 amI have a raid that i edit many HD projects on it so that’s not it also the sequence setting are exact as the clip and i still get the red line to render the clip
i am going mad , the only thing i am thinking is the codec.the audio of the sq is 32 bit flot and the clip is 16 bit big endian could that be the problem?Vid Frame Size: 1024×576
FPS: 25
