FCP when I try to render audio i get popup that says “not found”
So far we’ve tried moving everything to a new sequence, then a new project file, then changing the render settings.
The situation is that we can’t render any audio out. When you try mostly nothing happens, but sometimes a popup will appear that says “Not Found” and that’s it…
Thanks for your help.
