Activity Forums Apple Final Cut Pro Legacy FCP: When capturing the time code is 2 frames off??????
  • Francois Stark
    November 7, 2007 at 9:58 am
    Open Final Cut Pro -> audio/video settings -> Device control presets
    Select the device control setting that you are using and hit edit;
    Change the capture offset and test.
    Test it by just capturing a short piece and checking frame accuracy.
    F
