Activity › Forums › Apple Final Cut Pro Legacy › FCP weird white frame problem
  • FCP weird white frame problem
    Posted by Lisa sabina Harney on December 14, 2012 at 12:24 am
    Hey, I hope someone can help explain this one. I was running my project on a full spec tower mac, but due to travel and shooting, I migrated to my laptop with FCP 6.06. At first, every thing worked fine, but one day every time I stopped the play back of the edit, it came to rest on a white frame. When I export, all it exports is the white frame with sound. At first I thought it may be the drives, but they run fine, I resaved the project, ran them on a different project. No matter what I do, FCP see’s a white frame when I halt the edit. No matter which media I use. I am not able to run it on another mac at the moment, as 6.06 only runs on Snow Leopard and every other Mac I have access to right now is Lion. Anyone know what is happening here?
    Rafael Amador replied 13 years, 9 months ago 2 Members · 3 Replies
  • Rafael Amador
    December 14, 2012 at 8:36 am
    Hi Lisa,
    Normally you get a full white screen when the codec of the clip is not present on your computer.
    Which kind of codec are you using for exporting?
    rafael
    http://www.nagavideo.com
  • Lisa sabina Harney
    December 14, 2012 at 11:41 am
    Hi Rafael,
    thanks for your response. I was using MPEG 4, but I did change the export codec and its working to an extent, in that it is exporting the files now, when the computer doesn’t crash. 🙂
    However, the white frame problem persists in the edit itself, every time I stop playing the edit, it rests on a white frame, I am wondering if its because my laptop hasn’t enough power, as it all ran perfectly on my tower.
  • Rafael Amador
    December 14, 2012 at 12:44 pm
    Lisa,
    MP4 is not supported by FC, so you can expect whatever funny (no funny) behavior.
    rafael
