Activity Forums Apple Final Cut Pro Legacy FCP video card for HDMI and S-Video real-time monitoring
  • FCP video card for HDMI and S-Video real-time monitoring
    Posted by Carl on June 25, 2007 at 4:24 am
    Hello,
    We will be setting up a new FCP editing computer whic will be used to edit mostly in HDV. A lot of our projects are edited and mastered in HDV, but usually (for now) we downconvert them to SD for DVD usage. So we are looking for the best/value hardware solution. We will be viewing the HD footage on a Sony 40″ LCD with HDMI input, and a Sony CRT monitor with S-Video input. We would like them both to show realtime from an HDV timeline.
    The only possible solution I can come up with at this point is a Blackmagic DeckLink HD Extreme ($995) outputting to S-Video to monitor and SDI to a Blackmagic HDLink converter ($445) to HDMI monitor.
    Is this the only solution? Has anyone tried a similar approach? Will this setup keep sync? Would AJA’s new IoHD work for my needs? I don’t think I can justify it’s price though just for HDV editing….
    Any thoughts/suggestions would be appreciated.
    Dream Master replied 19 years, 2 months ago 3 Members · 4 Replies
  • Uli Plank
    June 25, 2007 at 5:24 am
    Why not get yourself the Intensity Pro from Blackmagic? It has both analog and HDMI. But check with them if it can provide SD to the S-video and HD to HDMI at the same time
  • Carl
    June 25, 2007 at 12:32 pm
    Thanks for the suggestion, but the Intensity Pro does not downconvert to SD monitoring in real-time – which is what I need. It does do HDMI, which is half of what I need, but I like the fact that the larger cards also do hardware rendering support for HDV…
  • Uli Plank
    June 25, 2007 at 12:45 pm
    But with DVI-Link you’ll probably get a different amount of latency
  • Dream Master
    June 25, 2007 at 1:32 pm
    Just a thought, but if your deck or camera that you have hooked up to it, should be able to do s-vid pass thru. I run dual LCD’s via DVI, and a CRT via my DSR25 S-Video Passthru….
    It works great for reference.
    DM
