Activity › Forums › Apple Final Cut Pro Legacy › FCP video and audio out of sync
  • FCP video and audio out of sync
    Posted by Theresqshop on August 26, 2007 at 9:30 pm
    I’m new to FCP, I’m using ver 5.1 on a Mac Pro with 3Gb RAM. I only have a single 160Gb HD.
    I’ve recorded raw video on a JVC HDD video camera and converted the raw footage to a m2v file for use in FCP. I’ve added the footage with a ChromaKey filter placing the video image in front of a still .jpg.
    The problem: I’m noticing that as I add a series of jpg’s changing the background periodically, the video gets ahead of the audio, typically by about 4 frames. I have to go in, unlink the m2v file, slide the video back (about 4 frames) and they are sync’d again, but it’s only temporary.
    Can anyone explain to me what is going on and more importantly can it be stopped?
    Will Wingfield
    The ResQ Shop
    Richard Harrington replied 16 years, 1 month ago 5 Members · 11 Replies
  • 11 Replies
  • David Battistella
    August 29, 2007 at 11:36 pm
    Why would you edit an m2v file. Can’t you extract a real format from that camera?
    David
    Peace and Love 🙂
    Read my Blog
    https://blogs.creativecow.net/DavidBattistella
  • Theresqshop
    September 1, 2007 at 3:36 pm
    The Everio had proven very difficult to use with the Mac and FCP. I was finally able to get an mpg off the camera but I hadn’t been able to find an editable format until I found a software that would demux the mpg into an m2v and an aiff. Do you have a better suggestion? I’d sure be willing to try anything.
    Is there a specific reason why I shouldn’t edit the m2v? It appears to give me a video and audio file that are initially linked and sync’d. During the edit process the video seems to become unsync’d and need about a 4 frame nudge periodically.
    Thoughts?
    Will Wingfield
  • David Battistella
    September 1, 2007 at 5:18 pm
    Will,
    M2V is a long GOP format. This means that the video is represented in I and P frames. each frame is not assigned one timecode frame. What happens is and I frame gets drawn and then several P frames are drawn to “look” like the I frame.
    In DV, for example, this does not exist. There is one frame represented for each timecode number.
    David
    Peace and Love 🙂
    Read my Blog
  • Theresqshop
    September 1, 2007 at 5:34 pm
    I’m not familiar with the term “GOP” so I’m a little lost.
    What file format would be ideal for editing purposes?
    It appears with this 3rd party software I have I can convert the mpg from the camera with the options of;
    demux to m2v and aiff
    demux to m2v and m1A
    demux to m2v and AC3
    I can convert to
    MPEG with MP2 Audio
    Headed MPEG
    It will also demux to ‘headed’ versions of the options above.
    Any other thoughts?
    WW
  • Tom Wolsky
    September 1, 2007 at 6:11 pm
    What’s the software?
    You want the first one.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Theresqshop
    September 1, 2007 at 6:14 pm
    The software is called MPEG Streamclip.
    The first one is demux to m2v and aiff, that’s what I’ve been using but you suggested the m2v option wasn’t good.
    I’m confused more now.
    WW
  • Tom Wolsky
    September 1, 2007 at 6:39 pm
    Sorry, my fault. You don’t only want to demux; you also want to convert the file.
    Use the QuickTime export function. Set the codec to Apple DV either PAL or NTSC depending in what you’re working in and the frame rate to 25 or 29.97 depending on whether you’re using PAL or NTSC.
    All the best,
    Tom
  • David Battistella
    September 1, 2007 at 7:28 pm
    GOP (group of Pictures)
    Convert to a Panasonic DVCPRO codec for best most consistent results.
    David
    Peace and Love 🙂
    Read my Blog
  • Tom Wolsky
    September 1, 2007 at 7:47 pm
    I’ll stay out of this, but I think the camera’s shooting in SD. Do you mean upconvert it to DVCPRO50? Maybe. Not sure what the gain would be.
    All the best,
    Tom
  • Suresh Sukumaran
    August 9, 2010 at 7:32 am
    Hello . In my FCP Audio and Video are zinc in my editing room . But when i transfer the video and audio for Dub in dubbing room. there is zinc problem (video length is short and audio length is normal).Any one knows the problem please help me.
