Activity Forums Apple Final Cut Pro Legacy FCP Version 6.0.0 Log and Capture Issues
  • FCP Version 6.0.0 Log and Capture Issues
    Posted by James Dow on August 8, 2012 at 3:23 pm
    Ok…the project from hell that requires me to go back through 8 years of Mini DV tapes…Dropped frames…abort of Log and Capture…I’ve unchecked the “abort” boxes in the A/V setup area…any other things to check? At this rate, this is gonna take a long, long time.
    Suggestions???
    Thanks in advance,
    James Dow
    JPD
    James Dow replied 14 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    August 8, 2012 at 4:49 pm
    The .0.0 versions of apps are very rarely stable. Use the SYSTEM UPDATE to update FCP (called the ProApps update) to the latest version, which I believe is 6.0.8.
    But also, what sort of drive are you capturing to? How is it connected? Is it at least 7200RPM (many drives are 5400 RPM)?
    Shane
    Little Frog Post
  • James Dow
    August 10, 2012 at 8:53 pm
    It seems ok now…trashed preferences..restarted….to answer your question, Shane, I was capturing to a Seagate “go-Flex” drive, via USB 3.0, just to make files out of the old Mini DV tapes…I will be editing the files next week.
    I believe the G-Flex is 7200RPMs.
    James
    JPD
