Activity Forums Apple Final Cut Pro FCP Updates wish list from a one week edit
  • FCP Updates wish list from a one week edit
    Posted by Bret Williams on March 30, 2014 at 4:03 pm
    Seems like a slow weekend, so thought I’d post this…
    A few weeks ago I decided to make a list of every want or need as I came across it during a one week edit. Since these are quick notes roughly categorized, I apologize if they don’t completely make sense. I don’t remember what I was talking about in a few of them. There are of course many other things I’d like to add or change, but the exercise was to only take note of what I needed on a fairly standard one week corporate edit. It was motion template heavy, but not color correction heavy or audio sweeting heavy. I’d post it but it was an internal piece.
    I’m sure I could come up with a similarly long list in Premiere or Legacy. Without further ado-
    FCP Update wish list from a one week edit:
    TRIMMING
    Trimming/Sliding on client monitor
    Trimming/Sliding 4 UP display
    Trimming/Sliding same features in keyboard entry mode as mouse mode
    Trim multiple layers at once
    Dynamic Trimming
    MATCHFRAME
    go back to keyword collection it came from
    make it OBVIOUS which clip it is. Hard to see in thumb mode
    Don’t constrain to in/out
    BROWSER
    Multiple Browser windows
    “Thumbnail” as a column choice in list view
    EFFECTS WINDOW
    Add a list view to effects window
    Favorites and or Project fx
    FX saved with project somehow
    COLOR CORRECTION
    Mask tracking and custom shape
    on/off toggle on every board
    INSPECTOR-
    VIDEO
    Leave the blend modes and opacity at the TOP
    (and for that matter, put them back in the timeline with a right click)
    Copy/Paste/Drag filters and settings right in/from the inspector
    TRANSITIONS
    Need start on edit, end on edit, center on edit options
    PASTE ATTRIBUTES
    Add back “paste content”
    SELECTING
    Let me marquee a group of secondary timelines
    Select/Marquee select multiple trim/transition points (for adding transitions or trimming)
    SAFE GUIDES
    Should be shown on client monitor
    Snap to grid/rulers
    FX
    Basic X and Y rotation added to Z rotation
    Drop Shadow FX heads up controls shouldn’t be shown if clip not selected – ditto with all fx
    TRANSFORM TOOLS
    Better shift to lock X/Y
    Proper ease controls
    Nudge position in viewer with arrows (like option + arrows in legacy)
    INTERFACE
    Tabbed Projects (sequences)
    Ganging
    Turning off connections visibility should also compress vertical space
    A mode where all clips are expanded all the time so you don’t have to expand each clip as it’s place in sequence
    Clip height hot keys
    SNAPPING
    Allow shift to be held to snap to vertical when option is being held to duplicate and clip is being dragged up or down
    COMPOUND CLIPS
    Double click into clip takes you to same frame from external sequence
    EVENT VIEWER
    Scrub bar/thumbs in window
    Ability to drag from window
    Ability to show a clip/frame from the sequence with all effects applied, for color correction reference or edit into separate sequence
    TIMECODE
    Copy and Paste TC
    Need a “counter” mode instead of just TC.
    Caps lock to disable rendering/animation while moving things around
    PREFERENCES
    Playback offset adjustment to keep external monitor in sync
    SOUND
    Sound should be routed to the output device. Shouldn’t have to select it in os prefs and share with os system sounds
    AUDIO TOOLS
    Give me a keyframe bar/line to pull up/down volume in thumb/list view on audio to adjust in event – why not adjust/keyframe audio here?
    HAND TOOL
    Moves the sequence the wrong way vertically, but correctly horizontally WTF?
    SYNC MARKERS
    Show where detached audio is out of sync
    SCOPES
    Multiple scopes at once
    MOTION
    Open in Motion for templates already put in timeline
    Send to motion for sections of timeline
    TITLES
    Should add the effect to titles, not the title to the effect (not holding my breath) IOW you make a text, then apply an animation to it like in motion or LiveType
    KEYFRAMES
    Delete key should delete highlighted keyframes, not the clip
    EXPORT
    Show the background process window even when FCP X is just a background window
    MEDIA MANAGEMENT
    Have a “consolidate files” checkbox anytime you duplicate a library, or create a new library from a project
    Bret Williams replied 12 years, 6 months ago 4 Members · 6 Replies
  • Andy Neil
    March 30, 2014 at 4:58 pm
    Can really disagree with what you have here except for a few that I think are unnecessary and a couple I think are extremely unlikely due to how the GUI is designed. So, I’ll add a couple that I’d like to see as well.
    Proper playhead to playhead replace edit.
    Multi-tiered matchframe. IE: Matchframe a multiclip and it takes you to the multi clip in the browser. Matchframe from there and it takes you to the original source clip used in the multi clip. Same with compounds.
    Sort by Unused clips.
    When you clear an IN/OUT from a clip in the browser, I’d like the playhead position to NOT be reset to the beginning of the clip. If I want to start from the beginning, I’ll hit the HOME key.
    Project scrubbing in the event browser.
    Project to project editing. IE: project treated like a clip in the browser.
    When a clip is selected (C) and you blade that clip, the clip to the RIGHT of the playhead should remain selected, not the LEFT. I don’t know what they were thinking with that.
    Ability to put overlapping connected clips into a secondary storyline.
    Andy
    https://plus.google.com/u/0/107277729326633563425/videos
  • Bret Williams
    March 30, 2014 at 5:20 pm
    All excellent adds. My list was just an exercise in what came to mind as I came across them over a week. Certainly a few are unlikely, and had it been a multicam project the list would’ve been different.
  • Andy Neil
    March 30, 2014 at 5:39 pm
    Regarding your “apply effect” to text request. That’s one of those that I doubt will ever happen due to how Motion and FCPX interact with one another. However, you can customize some animation by using the basic title. And personally, I built a title effect in Motion that contains a drop down menu of my most used text animations so I can apply a single text element and animate it a number of ways. Might be an adequate solution.
    Andy
  • David Powell
    March 30, 2014 at 7:33 pm
    Playhead resetting at the head of the clip is one of the most annoying behaviors in the software!
    Matchframe to orignal clip from multi clip. Allow CC grouping of multi clips. Allow Optical flow and stabilization of multi-clips!
    Trimming:
    A real extend edit that doesn’t require clicking on the edit point first. Premiere stole it from Avid. Please do the same Apple! Select nearest edit trim.
    Media Management:
    Used media only consolidation.
    External Render, proxy, and trascoded files from the library.
  • John Fishback
    March 30, 2014 at 9:13 pm
    Good thoughts all. If you’re not aware of them, CoreMelt’s SliceX and TrackX (both powered by Mocha) are tremendous tools and not too expensive. They each paid for themselves the first time I used them.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Bret Williams
    March 30, 2014 at 10:43 pm
    That’s one of those I wasn’t sure what I had meant. But I think you got it. And yeah, not holding my breath.
