Activity Forums Apple Final Cut Pro Legacy FCP transition problem using transparent Tiff
  • FCP transition problem using transparent Tiff
    Posted by Jeremy Schoenwald on December 3, 2009 at 6:25 pm
    I’m having a problem with transitions in FCP. I have a video layer on V1 and overlay a tiff text graphic on V2 using an edge wipe (although I experience the same problem using a simple cross dissolve). The problem is that the last frame of the transition and the next frame do not match. The last frame of the transition is slightly brighter than the remainder of the graphic. I think it may be some sort of alpha issue. I tested different transparency settings on that last frame and ruled that out as the problem. Any ideas?
    Jeremy Schoenwald replied 16 years, 9 months ago 3 Members · 3 Replies
