Activity Forums Apple Final Cut Pro Legacy FCP to Sony HVR-M15U to Monitor?
  • FCP to Sony HVR-M15U to Monitor?
    Posted by Tony Rath on July 25, 2008 at 1:53 am
    I am running FCP 6 and have no problem capturing HD off a HVR-M15U recorder, but I can’t view video from FCP through the recorder to a video monitor for color correction.
    Having a hard time finding the proper settings for both FCP and the recorder to do so. I see recurring references on here that it can be done, but no directions on the setup.
    Any hints? Thanks!
    Richard Clark replied 18 years, 1 month ago 3 Members · 4 Replies
  • Colin Mcquillan
    July 25, 2008 at 2:33 am
    If I understand correctly there is no real time playback monitoring of HDV VIA a firewire deck. You need either a AJA/BM capture card or an MXO
    Colin McQuillan
    Van. B.C.
  • Richard Clark
    July 25, 2008 at 3:20 am
    I have the same set up and was using it with P2 a month ago and it worked seemlessly. I will dig out the deck, I am moving house as I edit a short film, and check what I did,R.
    Richard Clark’s kiwicafe.com
    Film Editor & . . .
    https://kiwicafe.blogspot.com/
    NZ & US & . . .
  • Colin Mcquillan
    July 25, 2008 at 3:51 am
    I have an AJA card, so all my monitoring goes through that,, but a while back, before i got the card I rented a M15U for a project, and had the same problem, no playback, only still image when playback stopped. After “reading the manual” I found that you cannot watch realtime NLE playback of HDV material via firewire to the deck until output or the timeline is conformed or something of the sort.
    [Richard Clark] “I have the same set up and was using it with P2 a month ago and it worked seemlessly. I will dig out the deck, I am moving house as I edit a short film, and check what I did,R.”
    Perhaps you can with P2 material. I imagine you convert the P2 material to something other than HDV?
    Colin McQuillan
    Van. B.C.
  • Richard Clark
    July 27, 2008 at 6:27 am
    nope, we didn’t convert anything, it came in from the Contents file, i must admit i was amazed. Now, my most recent venture with P2 on a panasonic 502 created more of a challenge but thanks to this forum I was able to fix the problem and now feel like an old pro . . . .wait a minute, I am an old pro. good luck, Richard.
    Film Editor & . . .
    NZ & US & . . .
