FCP to Premiere Pro CS5 with MXO2 mini questions
I’ve been using FCP for 10 years, and I’ve had premiere in my Adobe production bundle since CS3. I use the matrox mxo2 mini for in/out. Since it also works with Premiere, and the latest premiere seems to have some great features I thought I’d do a few tutorials and such. I’ve been able to open some ProRes 422 1080i projects and also bring in some prores 1080i clips. But just in browsing around I found one thing that might be a bug. I’ve got the matrox player for the editing mode, and have a new sequence setup with the matrox mxo2 1920x1080i preset. All seems to be well and the clips play back in the sequence with no rendering needed. But they consistently drop frames unless I put them on 1/2 res. FCP wouldn’t have even blinked at playing back these files (from a GRaid esata drive). So maybe I need to do something to optimize playback. But the bug I found was that if I turn on the title safe in the program monitor, when I hit play it goes to white. I have to muck around for awhile turning settings on and off until it will go back to the actual program view. All the while the matrox outputs just fine. Dropping frames of course. And it seems that if you turn off report dropped frames, it keeps playing, but keeps drifting farther and farther out of audio sync. So bear with me, this stuff doesn’t seem to happen unless using the mxo2, so wondering if it’s just a bug or what. mxo2 is the latest, premiere is the latest, and OSx is the latest.
