Activity Forums Apple Final Cut Pro Legacy FCP to color
  • Posted by David Ertley on February 20, 2009 at 7:10 pm
    I tried searching for this issue, but I didn’t find anything similar.
    I have a sequence in FCP 6.0.5 with all it’s attributes removed, ready to “move to” Color. I followed the steps in the Lynda.com video, and I found a forum posting here with additional steps.
    When I select the sequence, there are no clips highlighted. the sequence is even highlighted in the browser, and the timeline is the active window. When I choose “move to” “color”, I am prompted to name the color project, I click to accept the name, and Color launches. Color brings up an file open box for a brief moment and it goes away just as quickly. then the interface loads (slowly, all i see are 2 grey empty windows for a while). Once the program loads, there isn’t a single frame of footage brought over from FCP.
    This isn’t a hardware issue since I have moved FCP projects to Color on this Mac before. I don’t know of any steps I am missing, but it doesn’t work.
    https://davidertley.com/
    Walter Biscardi replied 17 years, 7 months ago 6 Members · 16 Replies
  • 16 Replies
  • Walter Biscardi
    February 20, 2009 at 8:19 pm
    Do you have a bunch of empty video tracks? If so, turn delete all the empty ones and consolidate everything down to as few video tracks as possible.
    I have a Tutorial right here on the Cow on prepping your timeline for Color.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • David Ertley
    February 20, 2009 at 8:51 pm
    I don’t, it is all on V1, there is no V2 (i deleted it)
  • Andrew Kimery
    February 20, 2009 at 10:59 pm
    How long is the project you are sending over, what codec is it in, and do you have an nested sequences in it?
    -A
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
  • David Ertley
    February 20, 2009 at 11:10 pm
    length: 01:14:30;25
    DVCProHD 108060i
    no nested sequences
  • Andrew Kimery
    February 20, 2009 at 11:36 pm
    It’s recommended to keep the timelines sent to Color around 20 minutes or 200 edits. Try that and see if it helps.
    -A
  • David Ertley
    February 21, 2009 at 1:22 am
    Are you suggesting I make it longer? it’s only 14 and a half minutes long right now.
  • Andrew Kimery
    February 21, 2009 at 2:23 am
    Ah, the way your previous post was written indicated that the timline was 1hr14min long which prompted me to say what I did.
    Instead of using the Send to Color command have you tried to export an XML from FCP instead?
    -A
  • David Ertley
    February 21, 2009 at 2:56 am
    yes, but I didn’t know how to then open it in Color.
    i select it in the open dialogue but when I click the “open” button nothing happens (the box doesn’t close either).
  • David Ertley
    February 21, 2009 at 5:00 am
    I exported an XML file and found how to import an XML file in color, but it still won’t open it.
  • Alex Gollner
    February 21, 2009 at 1:07 pm
    Visiting the Broadcasting Video Expo, I attended a seminar on FCP HD workflow presented by the BBC.
    My notes are summarised at
    https://alex4d.wordpress.com/2009/02/17/broadcast-video-expo-bbc-on-fcs/
    BBC graders…
    1. Export a ProRes QT from FCP
    2. Import that ProRes back into the source sequence
    3. Blade the QuickTime to match the edits in the source sequence
    4. Duplicate the source sequence
    5. Delete all video and audio tracks from the sequence except the sliced ProRes movie
    6. Move the movie to V1
    7. Send to Color
    8. Grade in Color
    9. Export as ProRes from Color
    10. Import the ProRes QuickTime to the duplicate sequence with the original edit
    11. Add captions
    alex4D
