Activity Forums Adobe After Effects FCP to AE and back
  • FCP to AE and back
    Posted by Michael Worth on April 4, 2010 at 12:43 am
    Hello,
    I have a problem possibly someone may help with. I am working on mostly music video’s I am exporting from FCP to AE adding effects and art and then exporting back to FCP. Everything looks great, but when I export from AE to FCP and open and replace the file into the previously editing footage, it is shorter in length.
    Currently I am adjust the time of the clip to make it fit back into the edit, but it is very time consuming.
    I am matching the settings in FCP and AE with frame rate and HD 1080i
    What may I be missing?
    Michael Worth replied 16 years, 5 months ago 2 Members · 2 Replies
  • Alperen T. ayhan
    April 6, 2010 at 7:45 am
    Is it posibble? I do not know, but check your composition settings. Or be sure; in timeline you have the same length as it’s shown below..
    Alperen T. AYHAN
    http://www.sinamasal.com
    Always cinema…
  • Michael Worth
    April 6, 2010 at 9:13 am
    Hi Alperen,
    Yes those setting are accurate. I thought it may have something to do with the compression or the fps, but they all match up when I read the clip description in the final cut window.
    Thank you for the input.
