Activity › Forums › Apple Final Cut Pro Legacy › FCP to 40″ TV
FCP to 40″ TV
Posted by Jan Kielland on February 27, 2008 at 10:26 amHi
Can anyone tell me the best way to get video on a 40″ TV straight out of FCP? I was thinking of getting a HDready plasma.
We pretty much do all our projects in SD.
Jan KiellandWalter Biscardi replied 18 years, 6 months ago 2 Members · 3 Replies -
Walter Biscardi
February 27, 2008 at 11:23 amFirst off, SD generally looks terrible on HD plasmas. We have four of them in the shop and even playing 8bit Uncompressed SD straight on to the plasma, they don’t look good because the image is being blown up so much to fit on that screen, even in pillarbox mode. HD plasmas are designed to play HD.
As for viewing to such TV, you haven’t told us your system specs, but you can purchase an AJA Io HD, AJA Kona LH, AJA Kona LHe, AJA Kona 2, AJA Kona 3, AJA Io. All of which will play your SD video to the screen, most of these will play HD to your screen as well. Some only work on older PCI-X systems and some only work on the newer PCIe systems.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Jan Kielland
February 28, 2008 at 12:17 pmThanks for your respons
We have a new super mac that supports the 30″ apple monitor and one available DVI out, I don´t have the rest of the specs, do you need them?
What adapter and TV would you recomend? I was thinking Panasonic pv70 or px70. A Sony LCD is also interessting, but It seems plasma looks better with camera movement.
Jan Kielland
Walter Biscardi
February 28, 2008 at 12:26 pm[Jan Kielland] “We have a new super mac that supports the 30″ apple monitor and one available DVI out, I don´t have the rest of the specs, do you need them?”
Yes, unless you want to purchase a Matrox MXO to convert your DVI to video for the plasma, but I don’t use or recommend those.
For the plasma screens I recommend the Panasonic Pro series 42″ model Generally this model is cheaper than the consumer version of the same screen.
PBTTH42P10UKAWalter Biscardi, Jr.
