Activity Forums Apple Final Cut Pro Legacy FCP timeline exported to Quicktime: footage jumps
  • FCP timeline exported to Quicktime: footage jumps
    Posted by Scott Wagner on May 27, 2009 at 5:20 am
    I shot a short documentary on a Canon HV30 in 30p. When I export it to quicktime and watch the video it jumps in several spots. The footage does not look this way on the timeline or in the canvas, so there is something wrong with the export. I have tried almost everything (I think) and it still jumps.
    These are my settings (although I have tried others as well)
    H.264
    Frame rate: Current
    Key frames: 30
    Data Rate: 5500 kbits/sec
    Dimensions: 1280×720
    Here is a link to the footage:
    https://vimeo.com/4604597
    Places where it jumps (a few examples): 00:44, 03:05, 03:08
    If anyone has seen this before and has a better workflow that they would like to share, I would appreciate it.
    Scott
    Scott Wagner replied 17 years, 3 months ago 2 Members · 2 Replies
  • John Fishback
    May 27, 2009 at 1:57 pm
    I saw a post a few weeks back with a similar problem. I think the solution was to trash the render files (using Render Mgr) and re-render. You might search to find that thread.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Scott Wagner
    May 28, 2009 at 12:32 am
    So thanks for your advice, I tried your suggestions and some of the footage stopped jumping, but when I took away the subtitles from the footage and exported it without the subtitles, the problem seemed to go away entirely. I need to have subtitles for these short docs, so would you have any suggestions as to why these texts above the footage make it jump when exported? Thanks again for your help.
    Scott
