Activity › Forums › Apple Final Cut Pro Legacy › FCP timeline and Dual Monitor
Posted by Yiannis Valkan on March 6, 2009 at 11:41 amHi all.
I know its a beginner question, but i always had it.
I have 2 19″ Cinema Displays on my macPro.
FCP timeline always stays at the first display and no matter what i try i cannot expand it to the second one. Does anybody have any ideas?
And the MACs title bar is on the first also. It does not expand to the second one.Thanx.
2 minds are better than one.
Walter Biscardi replied 17 years, 6 months ago 3 Members · 5 Replies -
Walter Biscardi
March 6, 2009 at 11:48 amYou should just be able to grab the lower right of the Sequence window and drag it out as large as you want. You need to have the Sequence on the Left monitor and drag to the right, it will not expand to the left.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Steve Eisen
March 6, 2009 at 1:11 pmWindows layout. There are several dual display options. You can even create your own custom layout. Learn keyboard shortcuts to activate them.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Yiannis Valkan
March 6, 2009 at 2:00 pmThank you both for your answers.
I already tried both solutions.
If i tried to drag the timeline from the lower right corner, it does NOT expand to the right. It stops at the edge of the 1st monitor. Even if i move the toolbar and the audio levels bar, it still stays at the 1st.
I also tried to set all the different windows layout, but still no result. I even placed the timeline between the 2 monitors, saved the layout, and everytime i try to restore it, voila, it stays at the 1st monitor.I am thinking if there is an option for that on the vga’s display options like there is on the WindowsXP.
Steve Eisen
March 6, 2009 at 3:18 pmSounds like user error to me. You need to go into your display preferences and set up your displays correctly.
Steve Eisen
Board of Directors
Walter Biscardi
March 6, 2009 at 3:29 pm[yiannis valkan] “I also tried to set all the different windows layout, but still no result. I even placed the timeline between the 2 monitors, saved the layout, and everytime i try to restore it, voila, it stays at the 1st monitor. “
I don’t think you can save a window layout where the timeline stretches across 2 monitors. You can save it where the timeline will be on the left hand monitor and then pull it across both manually.
