Activity › Forums › Apple Final Cut Pro Legacy › FCP targa sequence
FCP targa sequence
Posted by Kresimir Rodich on February 5, 2009 at 9:17 amHi to all!
One fast and short question.
Does does anybody had a problem when exporting a targa sequence
with 1 extra frame at the start or at the end of sequence???
That issue is killing me 🙂 and it’s a problem with recreating a sequence back from fusion.tnx and refards, K.
Jeremy Garchow replied 17 years, 6 months ago 5 Members · 20 Replies -
Jeremy Garchow
February 5, 2009 at 4:03 pmI’d use something else such as After Effects or perhaps Motion if you don’t have AE. QT conversion is no good.
Kresimir Rodich
February 5, 2009 at 4:12 pmwe don’t use AE.
But my problem is next: clip in timeline is lets say 2sec and 7f,
so it’s 57 frames, but when same clip is exported in targa frames(sequence) i have 58 frames.
so it’s no mater wich copositing softeare i use, because i have 1f extra. 😀 -
Jeremy Garchow
February 5, 2009 at 5:55 pmWell, that depends. Are you counting that last frame, or counting the first frame 0 as frame 1? If you are, the end of your timeline will stretch to the beginning of frame 58 (but if you look closely it will fall on frame 57). If you go to the end of your timeline wihtout backing up a frame, the next frame of black will be on frame 58.
make sense?
Rafael Amador
February 6, 2009 at 4:40 am[Kresimir Rodich] “we don’t use AE. “
You can try with Motion.
Whatever solution better than QT.
Rafael -
Kresimir Rodich
February 6, 2009 at 8:25 am@Jeremy Garchow:
Count is 01(as 1st frame) thing is wen i import tga seq. back tu FC there’s 1f extra and its not black its a picture.
i thing there’s a big bug in FC, or something.
tnx, K -
Jeremy Garchow
February 6, 2009 at 2:35 pmSo when you bering in your TGA sequence, you start it on frame 1 and not frame 0?
I’ll have to test this out myself.
Jeremy Garchow
February 6, 2009 at 2:51 pmSo, I just put a 57 frame slug on a PAL timeline and put a tc generator on the clip. The tc goes from 00:00:00:00 (which is frame 1) to 00:00:02:06. That’s 57 frames.
I export a TGA sequence and reimport with each from coming in as one frame long. There’s 57 frames marked 1-57.
I then bring that in to the timline, mark an in at the first frame, hit end and back up one frame and hit out, and the time is 57 frames.
Kresimir Rodich
February 6, 2009 at 3:53 pmhmm, bloody hell, i dont know what’s fucked up in my settings.
i just can’t find, maybe handles is issue, what i doubt.
tnx man, more testing for me. 😀
