Activity Forums Apple Final Cut Pro Legacy FCP targa sequence
  • Slika Ton
    February 6, 2009 at 4:33 pm
    Why is AE or Motion better at exporting image sequences than a QT? Aren’t all of them based on QT anyway?
  • Jeremy Garchow
    February 6, 2009 at 4:45 pm
    QT Conversion seems to do weird stuff with gamma, quality and bit depth. Not all exporters are created equal, unfortunately.
    Jeremy
  • Slika Ton
    February 6, 2009 at 5:10 pm
    Yes, I’ve seen weird stuff, but I was under impression that same problems happen in AE and Motion as well, as they also use QT infrastructure for conversion…
    Other thing is, I’m not sure anymore what a proper functioning combination of OS, FCP, QT, Kona driver is? Is there a “magic combination” that don’t make gamma shifts and other problems right now? I had green flashes with prores hq codec in hd with Aja Kona LHe, and when I updated OS and QT green flashes mostly disappeared but gamma shifts are much more present and noticeable.
    I’m currently on a OS 10.5.6 QT 7.5.5 FCP 6.0.5 , kona 6.0.1… Would QT 7.6 and kona 6.0.2 improve things or make it more complicated? Or should I wipe of HD and start from scratch?
  • Rafael Amador
    February 6, 2009 at 5:19 pm
    Most of the users of AE, Shake, etc use still sequences instead of movies.
    Those applications offers more options for managing stills sequences.
    FC don’t understand about much about sequences.
    However you can export the TGA sequence from the time-line with Export to QT (no QT Conversion).
    May work better.
    Rafael
    http://www.nagavideo.com
  • Christopher Wright
    February 6, 2009 at 7:56 pm
    I have also found that FCP likes PNG sequences better than Targas.
    Dual 2.5 G5, IO, Kona LH, IO, Medea Raid, UL4D, NVidia 6800, 4Gig RAM
    Octocore 8 GB Ram, Radeon card, MBP, MXO
    Windows Vista Adobe Studio CS4, Vegas 8.0, Lightwave 9.3, Sound Forge 9, Acid Pro 7, Continuum 5, Boris Red 4, Combustion 2008, Sapphire Effects
  • Jeremy Garchow
    February 6, 2009 at 11:55 pm
    [Slika Ton] “Yes, I’ve seen weird stuff, but I was under impression that same problems happen in AE and Motion as well, as they also use QT infrastructure for conversion…
    Not really.
    [Slika Ton] ” Is there a “magic combination” that don’t make gamma shifts and other problems right now?”
    Where are you seeing gamma shifts?
  • Slika Ton
    February 7, 2009 at 7:52 pm
    In roundtriping to AE in the first place. Even in compressor when making mpeg 2 and some other files.
    What bugs me is the fact that everything was near perfect with FCP 5.1.4 and AE and QT of that era. So that just shows that it can be done.
    I know that there are workarounds with image sequences but that really makes the whole process more cumbersome and defies the purpose of QT movies as most convenient and fastest way of transferring and shuttling video around. And it used to work very well two years ago, too.
  • Jeremy Garchow
    February 7, 2009 at 10:27 pm
    First, quit everything. Then, try removing the AJAUncompressedcodec.component from your HardDrive > Library > Quicktime folder. Then launch AE and try again with all color management off.
    Jeremy
  • Slika Ton
    February 7, 2009 at 11:19 pm
    I removed AJAUncompressedcodec.component and first results look promising.
    I’ll play with it more tomorrow but so far 10 bit material looks as it is supposed to be.
    Do I need AJAUncompressedcodec.component at some point or can I just leave it in the closet?
    Thank You Jeremy for the help.
  • Jeremy Garchow
    February 8, 2009 at 12:31 am
    You can leave it in the closet as long as you don’t have nay legacy projects that used the AJA UC codec. I just put everything I don’t need in a folder called “Quicktime (disabled)” right next to the Quicktime folder. If I do need it, I simply move them from the disabled folder to the other folder. If you haven’t used AJA 2vuy in the past, you don’t need it now as the Apple UC codecs have been properly updated.
    Jeremy
Page 2 of 2
