Activity Forums Apple Final Cut Pro Legacy FCP stuttering H.264 clip
  • FCP stuttering H.264 clip
    Posted by Steve Cornell on March 22, 2011 at 9:42 pm
    Canon 7D clip is stuttering in the FCP viewer.
    I’ve transcoded the clip to ProRes 422. The clip was shot at 1080 with a shutter speed of 125. When I play the RAW CLIP in quicktime, there is no stuttering. Additionally, when I play the captured clip in quicktime player, its smooth with no stuttering.
    As soon as I load the clip in the viewer or drop it into a timeline, BOOM, stuttering.
    I’ve also opened the transcoded clip in Cinema Tools and it plays perfectly.
    Sequence settings: 1920×1080 29.97fps Apple ProRes 4444 Pixel Aspect: Square Field Dominance: None
    Clips Settings: 1920×1080 29.97 Apple ProRes 4444
    Shannon Carpenter replied 15 years, 5 months ago 8 Members · 15 Replies
  • 15 Replies
  • Chris Tompkins
    March 22, 2011 at 9:51 pm
    What drive are you playing your media off of?
    Chris Tompkins
    Video Atlanta LLC
  • Rob Grauert
    March 22, 2011 at 9:52 pm
    ProRes4444?
    That codec requires more bandwidth, 330Mbps I believe. What is your media stored on? A firewire hard drive might not cut it, although, I never worked with ProRes4444, so I can’t say for sure.
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Steve Cornell
    March 22, 2011 at 10:00 pm
    Hi Chris,
    Its an internal drive. Here’s where it gets stranger. My wife is on the same setup as mine and the same raw clip transcoded by her machine, plays smooth in FCP viewer and canvas. I copied her sequence settings tab for tab.
  • Steve Cornell
    March 22, 2011 at 10:12 pm
    I think its a playback setting. I took the stuttering clip and exporting to a quicktime movie (make movie self contained).
    I then opened the exported .mov clip in the FCP viewer and it stutters. BUT….If I open the exported clip in quicktime, its SMOOTH.
  • Chris Tompkins
    March 22, 2011 at 10:13 pm
    You shouldn’t edit with media on your internal (OS) drive.
    Your results will vary.
    Chris Tompkins
    Video Atlanta LLC
  • Rafael Amador
    March 22, 2011 at 10:21 pm
    To transcode H264, Prores 444 makes no sense.
    rafael
    http://www.nagavideo.com
  • Frank Giardina
    March 22, 2011 at 10:27 pm
    Shouldn’t the frame rate be 60?
    Frank Giardina
    17 Video Production
  • Frank Giardina
    March 22, 2011 at 10:45 pm
    Sorry… I meant the shutter at twice the frame rate, so 60.
    Frank Giardina
    17 Video Production
  • Steve Cornell
    March 22, 2011 at 10:54 pm
    Nope. shutter can be anything above 2x the frame rate. the most important proof is that the clip plays smoothly on my wife’s machine.
  • Steve Cornell
    March 22, 2011 at 10:55 pm
    Problem solved. Thanks to everyone for taking the time to help.
