Activity Forums Apple Final Cut Pro Legacy FCP Studio 2 install fails on G4 1.42 GHZ Dual
  • FCP Studio 2 install fails on G4 1.42 GHZ Dual
    Posted by Bruce Stubblefield on July 6, 2008 at 8:08 pm
    Hello,
    Editing a project shot on Mini-DV NTSC; Trying to use a G4 Dual Processor as a second machine (have an 8-core for more advanced tasks). Trying to install Final Cut Studio 2 on the G4 1.42 GHZ Dual, OS 10.4.11 with 2GB RAM and a ATI Radeon 9000 Pro Graphics card, and lots of room on the drives.
    On inspection, the installer says: “The installed graphics card does not support the Open GL features recommended by Final Cut Studio installer.” (hardware listed detailed below.) It goes ahead and installs anyway, but crashes instantly when I open it.
    Any ideas? Does anyone know what kind of AGP card that will work in this G4 that will satisfy the installer?
    Many thanks
    Bruce S.
    Hardware:
    Machine Name: Power Mac G4
    Machine Model: PowerMac3,6
    CPU Type: PowerPC G4 (3.3)
    Number Of CPUs: 2
    CPU Speed: 1.42 GHz
    L2 Cache (per CPU): 256 KB
    L3 Cache (per CPU): 2 MB
    Memory: 2 GB
    Bus Speed: 167 MHz
    Boot ROM Version: 4.6.0f1
    Serial Number: XB3260D0NP3
    ATI Radeon 9000 Pro:
    Chipset Model: ATY,RV250
    Type: Display
    Bus: AGP
    Slot: SLOT-1
    VRAM (Total): 64 MB
    Vendor: ATI (0x1002)
    Device ID: 0x4966
    Revision ID: 0x0001
    ROM Revision: 113-99702-130
    Displays:
    Display:
    Resolution: 1024 x 768 @ 75 Hz
    Depth: 32-bit Color
    Core Image: Not Supported
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Quartz Extreme: Supported
    Rotation: Supported
    Display:
    Status: No display connected
    Also tried with this card, same result:
    ATI Radeon 8500:
    Chipset Model: ATY,R200
    Type: Display
    Bus: AGP
    Slot: SLOT-1
    VRAM (Total): 64 MB
    Device ID: 0x514c
    Revision ID: 0x0000
    ROM Revision: 113-85710-227
    Displays:
    Display:
    Depth: 32-bit Color
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Display:
    Warren Eig replied 18 years, 2 months ago 3 Members · 6 Replies
