FCP Still Photography Settings Question
Hi-
I am a professional photographer and am starting to create 16:9 video DVDs of my images. Currently I am using the latest version of Final Cut Studio. My question is, what are the absolute best settings (Final Cut, Comptressor, DVDSP) to use to create a DVD of my images. They all will use a 3 second dissolve transition. Below are my current settings. It would be awesome if I could get some feeback on my settings and what I could do better.I first start with an 853×480 RGB TIFF (I have a higher resolution available. Should I be working in 1920×1080?)
In FCP Sequence Settings:
Frame Size 720×480
Aspect Ratio: NTSC DV (3:2)
Pixel Aspect Ratio: NTSC-CCIR 601/DV 720×480
Anamorphic 16:9 checked
Field Dominance: Lower (Even)
Editing Timebase 29.97QuickTime Video Settings:
Compressor: Animation (Is this the best codec to use?)
Quality: 100%
Advanced>Compressor: Depth: Millions of Colors+I then export to Compressor
From Compressor:
Setting: DVD Best Quality 90 Minutes 16:9
File Format: MPEG-2
Video Format: NTSC
Rate: 29.97
Aspect Ratio: 16:9
Field Dominance: Bottom FirstQuality>
Mode: Two Pass VBR Best
Average Bit Rate: 6.2 Mbps
Maximum Bit Rate: 7.7 Mbps
Motion Estimation: BestIn DVDSP:
SD DVD
Preferences > Encoding (Are these effective since I encode in Compressor???)
Field Order: Auto
Mode: Two Pass VBR
Bit Rate: 5.5 Mbps
Max Bit Rate: 7.2 Mbps
