FCP startup – “unexpectedly quit”
Yesterday I tried to open Final Cut (v. 4.5) for the first time in a couple of weeks on my G4 Dual 1GHz (OS 10.3.9) and I immediately got the “application has unexpectedly quit” message. I tried restarting repeatedly, but the problem remains.
I’ve run this program without a hitch for two years now. It’s an upgrade from the earlier versions, and I do recall that, when I first installed it, i couldn’t get it to run until finally someone clued me in that there was some sort of bug that I had to eliminate by entering some code or other in Terminal, I think it was.
The only change I’ve done recently that might have caused the problem is that I did some housekeeping in my dock, and deleted the icon for the old FCP 3. Maybe I disrupted the pathway by doing this??? Unfortunately, I can’t reinstate the alias in the dock because I had FCP3 uninstalled a few months ago.
So, do you have any suggestions? Can I cure this by reinstalling 4.5, or even 3.0?Thanks,
lburke2
