Activity Forums Apple Final Cut Pro Legacy FCP speed with HD media vs Vegas/Premier on windows
  • FCP speed with HD media vs Vegas/Premier on windows
    Posted by Doug on June 23, 2005 at 1:26 pm
    I was recently told that rendering HD in FCP is extremely slow compared to windows based systems. More to the point…1.5 hours for a 3.4ghz Intel (single) vs 6.5 hours for a dual 2.5G5. It was the same clip and by ‘render’ I admist I’m not sure I know what is meant. I assume it is just the video being converted out to another HD file (no filters, text, graphics).
    I have not worked with HD video at all, nor have I worked with Vegas or Premier Pro on the windows side of things. Are these numbers about what one would expect? If so, it seems FCP is really behind in terms of HD performance. If not…what might cause such a disparity in performance of these systems?
    Doug replied 21 years, 2 months ago 2 Members · 2 Replies
  • Les Kaye
    June 24, 2005 at 8:18 am
    [Doug] “what might cause such a disparity in performance of these systems? “
    I can talk about an initial comparison of the same clips on our FCP & Avid AdrenalinesHDs (on a PC): FCP is WAY faster (4-5X faster).
  • Doug
    June 24, 2005 at 2:36 pm
    can you post specs of both (processor speed, HD size and setup, memory, sw versions, os…)
