Activity Forums Apple Final Cut Pro Legacy FCP shots with identical names
  • FCP shots with identical names
    Posted by Rick Tejada flores on November 11, 2009 at 11:44 pm
    I am trying to clean up a project that has two sets of P@ clips on different drives, with identical names. Is there an easy way to rename 100 clips? Does it make sense to re-import the P2 files again? Any other approaches?
    Jeremy Garchow replied 16 years, 10 months ago 3 Members · 2 Replies
  • Shane Ross
    November 12, 2009 at 12:15 am
    [Rick Tejada Flores] “a project that has two sets of P@ clips on different drives, with identical names.”
    Are they the SAME media files? Because P2 is supposed to have unique file names so that you wouldn’t run into a duplicate name.
    [Rick Tejada Flores] “Is there an easy way to rename 100 clips? “
    Have an assistant do it for you. No, you have to manually change the name…preferrably some sort of description, then either use the RENAME function in FCP (PREFERRED), or do it on the finder level, and reimport the clips. Best to do it in FCP and rename the files to match the clips.
    [Rick Tejada Flores] “Any other approaches? “
    Looking for the EASY button? Editing doesn’t have an Easy button for many many things.
    Shane
  • Jeremy Garchow
    November 12, 2009 at 2:15 am
    Is it the same exact media? Why not trash one and save the other?
