Activity › Forums › Apple Final Cut Pro Legacy › FCP settings using DVCPRO50 thru SDI via AJA???
  • Walter Biscardi
    May 1, 2005 at 9:35 am
    Use the Easy Setup and everything will be pre-set for you. That’s the easiest way.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Rainer Wirth
    May 2, 2005 at 7:43 am
    Video Audio settings, AJA SDI 10 Bit to DVC Pro 50, 422 Panasonic Machine control, manual audio Ch1/2 in out, Sequence Dvc Pro50.
    Rainer
  • Andrew
    May 2, 2005 at 9:26 am
    Should I be on upper or lower fields???
  • Rainer Wirth
    May 3, 2005 at 10:34 am
    To me there’s no difference.
    Rainer
