Activity › Forums › Apple Final Cut Pro Legacy › FCP settings for the JVC HM750
  • FCP settings for the JVC HM750
    Posted by Simon White on April 10, 2011 at 1:36 pm
    Hi all,
    I’ve just acquired the new JVC HM750 and shooting in HD. I can obtain a mov file and put it straight onto the timeline. But what does the HD setting on FCP need to be before adding the clip to the timeline.
    Many thanks
    Chris Tompkins replied 15 years, 5 months ago 3 Members · 11 Replies
  • 11 Replies
  • Chris Tompkins
    April 10, 2011 at 4:29 pm
    You didn’t mention what version FCP you have but if it’s new enough when you drop a clip into a new/emty sequence FCP will prompt you to alter the settings to best match your clip. Makes it easy.
    If you don’t have this, then choose an easy setup that matches what you shot. Create a new sequence AFTER you have choose an easy setup.
    Chris Tompkins
    Video Atlanta LLC
  • Simon White
    April 10, 2011 at 5:03 pm
    It’s FCP version 7.0.3, and yes it does prompt me to do so but once I’ve edited it, I need to export it as an HD clip still and that’s where I’m lost.
  • Zane Barker
    April 10, 2011 at 5:39 pm
    Well first we need to know what codec that camera uses for it’s video files.
    **Hindsight is always 1080p**
  • Chris Tompkins
    April 10, 2011 at 6:41 pm
    Your original post said what settings b/4 adding to timeline….
    Edit HD.
    Export “Current Settings”
    Drop that file into a compression program to create files for web or dvd or BD
    Chris Tompkins
    Video Atlanta LLC
  • Zane Barker
    April 11, 2011 at 3:05 am
    “original post said what settings b/4 adding to timeline” Chris Tompkins
    No it didn’t tell what settings all the original post said wad mov file. That could mean any one of hundreds of codecs.
    The reason it’s important to know what codec that camera uses to record is because many cameras do not record in a format that is naitivly FCP compatible, so they need to be converted to a proper editing codec before bringing it into FCP.
  • Simon White
    April 11, 2011 at 11:15 am
  • Simon White
    April 11, 2011 at 1:07 pm
    What the camera is telling me for HD:
    system definition – HD(MPEG2)
    file format: QuickTime
    camera resolution: 1920×1080
    frame & bit rate: 50i(HQ)
  • Simon White
    April 11, 2011 at 1:22 pm
    The codec is:
    XDCAM EX (35mbs) for HD
    25mbs for DV
  • Chris Tompkins
    April 11, 2011 at 2:16 pm
    Camera Specs:
    Record footage directly in ready-to-edit QuickTime™ MOV files,
    the native file format of Apple’s Final Cut Pro™, or in MP4 format
    (XDCAM EX™ workflow-compatible) for direct editing in other
    major NLE systems, including Avid Media Composer, Adobe
    Premiere and Canopus Edius Pro. Native file recording means no
    transcoding or file-wrapping is necessary,
    resulting in more efficient workflows and no loss
    of image quality.
    So Shoot HD.
    Edit HD.
    Drop that file into Compressor and create a file for DVD, Web, BD
    Chris Tompkins
    Video Atlanta LLC
  • Simon White
    April 11, 2011 at 3:15 pm
    Thanks Chris,
    Ultimately some of my clips are going on TV so I send them on to an ftp site, so the file needs to sit on my desktop until it’s ready. Would there need to be different settings, as the file could be too large to send via ftp.
    I’ve set the easy setup settings to XDCAM EX 35mbs
