  • Posted by Paolo Mugnaini on October 7, 2006 at 1:41 am
    Hello i just recently moved from Avid to FCP and i am having a # of issues.
    i have a power mac G5 DUAL 2.2 with 4.5 GB of DDR ram
    1) what’s the best way to set up the system so that i can have the problems processing stuff.
    2) RT effects are not working…the video becomes grainy, drops frames etc.
    3) i have an externa HD with a lot more spacethat the mac HD can i allocate EVERYTHING related to FCP there? except the app itself of course.
    4)help……please. i’m trying with books etc. and i am lost especially when it comes down to fx, in avid there’s an effect palette with…well you know it. here it’s so different.
    thanks
    Paolom
    Enzo Tedeschi replied 19 years, 11 months ago 3 Members · 3 Replies
  • Richard Harrington
    October 7, 2006 at 3:38 am
    Few things…
    Make sure timeline set to unlimited RT (drop down menu in Timeline corner)
    You can target FCP Studio support media only during install (part of Custom install options. As far as capture and such.. of course…. just change System Settings.
    As far as learning.. suggest you look t both FCP on the Spot (a book) and aboslute Training for Final Cut Studio… Good for those who are experienced editors trying to amtch the witch quickly
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
  • Paolo Mugnaini
    October 8, 2006 at 1:35 am
    thanks…so should i re-install FCP? if so what settings should i use?
    i’m going nuts-
    thanks
    Paolom
  • Enzo Tedeschi
    October 8, 2006 at 4:04 am
    Paolom,
    the system settings are in the Application Menus. The “Easy Setups” take the brainwork out of settings – thery are settings templates.
    Have you read thru the manual? You’ll probably be OK for most things coming from an Avid, but this sort of stuff is the nuts and bolts in the first few chapters that will save you a lot of these headaches if you go in armed with the knowledge…
    Enzo Tedeschi
    ____________________________
    Editor
    http://www.outpostpps.com
    Sydney, Australia
    Check out our latest music video – http://www.outpostpps.com/thebleed/
    Look out for the Outpost PPS Video Podcast launching in October
