Activity Forums Apple Final Cut Pro Legacy fcp set up to import pdw 700 xdcam footage
  • fcp set up to import pdw 700 xdcam footage
    Posted by Jay Kuntz on April 28, 2009 at 2:46 pm
    I need a basic step by step guideline for setting up FCP 6.0 so that I can import from my new Sony PDW700.
    I have the application software disc from Sony, where do I put the files?
    Once I have imported the files to the proper place, what are the steps needed to import files from the camcorder via firewire?
    Is translation done automatically from XML to Quicktime.
    What format are the proxy files and how does FCP deal with them?
    I am primarily a shooter, and currently use FCP as a basic tool for rough cutting material I have shot. So when I say I need a basic step by step guideline remember you are helping a “lens monkey” not an editor.
    J
    Jay Kuntz replied 15 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    April 28, 2009 at 3:25 pm
    Hi jay,
    here you have a good guide:
    https://www.sony.co.uk/res/attachment/file/95/1133797571595.pdf
    You can also ask in the SONYCinealta Forum in the COW.
    rafael
    http://www.nagavideo.com
  • Stuart Simpson
    April 28, 2009 at 3:47 pm
    [Jay Kuntz] “I have the application software disc from Sony, where do I put the files?”
    I wouldn’t use that disc myself – get the latest version of the XDCAM transfer software from the Sony website instead. The current version of XDCAM Transfer is 2.9.0
    https://servicesplus.us.sony.biz/sony-software-model-PDZKP1.aspx
    -Simmie
    6 MacPros – Kona 3 & Kona LH
    1 G5s – Kona LH
    xbox360, Wii, PSP, PS3
    https://www.speak.co.uk
  • Jay Kuntz
    April 28, 2009 at 9:07 pm
    Good idea to download newest version…I think.
    Loading update went smooth, but in the SONY XDCAM TRANSFER SET UP window it showed that I was missing XDCAM EX codec and XDCAN HD422 codec.
    I was able to access the disc via fw on the cam but it only shows proxys and on each clip is NO CODEC.
    Do I need to get the HD422 and EX codecs from somewhere else?
    Is this a setting on the install I overlooked?
    I want the clips as QT files right?
    J
    J
  • Rafael Amador
    April 29, 2009 at 1:11 am
    Hi Jay,
    You need to update FC to 6.02 at least.
    A good opportunity, because FC 6.0 is very buggy.
    rafael
  • Jay Kuntz
    April 29, 2009 at 1:47 pm
    THANK YOU!!!
    I do not visit the Cow often, but when I do I get GREAT info. If only the rest of the internet would work this way.
    J
    just added a photo for ID…I am the one on the right
    J
  • West Barba
    September 30, 2010 at 3:03 am
    I have the same problem right now. Did you found out more info about this question. Thanks.
  • Jay Kuntz
    October 1, 2010 at 1:39 pm
    The earlier advice seemed to work and all seems to be working fine.
    J
    J
