Activity › Forums › Apple Final Cut Pro Legacy › FCP Sequence to DCP
  • FCP Sequence to DCP
    Posted by David C jones on August 6, 2012 at 9:05 pm
    Greetings,
    Are there standard settings (or recommended settings) for final output for a DSP? My timeline is ProRes 442HQ @ 23.98p.
    Thanks in advance!
    Dave J
    Russell Lasson replied 14 years ago 3 Members · 3 Replies
  • Joseph Owens
    August 7, 2012 at 8:20 pm
    Here’s a starting point:
    Q: Does the Academy of Motion Picture Arts and Sciences accept DCPs when qualifying for an Academy Award?
    A: Yes, but to comply with Academy rules, your DCP must meet the following specifications:
    Video: 24.00 frames per second
    Compression: JPEG2000
    Color Space: XYZ
    Video Format: 2K – 2048×1080 container size (1920×1080, 1998×1080 and other image sizes are acceptable)
    Audio Format: 24-bit, 48 kHz uncompressed
    Minimum 3 channels (Left,Right,Center) or 5.1 (L,R,C,LFE,LS,RS)
    Audio Channel
    Mapping: 1:Left 2:Right 3:Center 4:Subwoofer 5:Left Surround 6:Right Surround
    Encryption: Unencrypted material only
    Q: Where can I find more complete technical specifications for DCPs?
    A: Complete DCP specifications are contained in the following:
    SMPTE 428-1-2006 D-Cinema, ISO/IEC 15444-1, SMPTE 428-2-2006
    D-Cinema, SMPTE 428-3-2006 D-Cinema
    Most of the DCP software manufacturers have more information, and as you work your way through configuring a compression run, you will find out more information.
    You can try Qubemaster, Doremi, Quvis, … there are about 2 or 3 dozen suppliers, now.
    The trick is figuring out how to play them back, so you know you’re not just delivering a big directory of corrupted data.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • David C jones
    August 8, 2012 at 2:31 am
    Hey Joseph, thanks for the info. So in the Use QuickTime Conversion, should I use the image sequence? And if so, should it be JPEG 24 or 23.98?
    Best,
    Dave J
  • Russell Lasson
    September 21, 2012 at 8:19 pm
    David,
    There are many ways of creating a DCP, but just exporting a JPEG2000 image sequence from the QT conversion menu in FCP isn’t really helpful. As Joseph mentioned, there are several programs that can help. It will take some trial an error and testing on a DCI server (at a theater) before you’ll be sure what you’ve created actually works. Or you can find someone to create the DCP for you.
    Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
