Activity Forums Apple Final Cut Pro Legacy FCP sequence settings
  • FCP sequence settings
    Posted by Rick Davis on August 10, 2009 at 5:52 pm
    I’m about to output a file from FCP 5.1.2 to BetaSP for standard def television broadcast. My question is regards to the correct sequence settings I should be using.
    The broadcaster will accept standard definition 4 x 3 material. The video portion of my spot was all created at another company using the ‘animation’ compressor with a 720 x 486 frame size and pixel aspect stated as NTSC-CCIR 601.
    Which aspect ration should I be setting my FCP sequence settings to:
    NTSC 4:3 or
    CCIR 601 NTSC 40:27 or
    CCIR 601 NTSC sq. 4:3
    Also which Quicktime Video compressor setting should I be using to provide the best possible quality for broadcast? :
    Animation (as the animation house used) or
    Uncompressed 8-bit 4:2:2
    Any advice would be much appreciated.
    Rick Davis
    Rick Davis replied 17 years, 1 month ago 2 Members · 2 Replies
  • David Roth weiss
    August 10, 2009 at 6:10 pm
    The animation codec is not a realtime codec in FCP, nor is it really a preferred QT editing codec. Use the Easy Setup and select Uncompressed 8-bit 48 kHz – it will properly set the aspect ratio for you, which is CCIR 601 NTSC (40:27).
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Rick Davis
    August 10, 2009 at 6:29 pm
    Thanks David, I’ll do that.
