Activity › Forums › Apple Final Cut Pro Legacy › FCP says “Project Not Found” when opening project
  • FCP says “Project Not Found” when opening project
    Posted by Alejandro Marin on December 13, 2005 at 7:05 pm
    Running FCP 4.5 on Dual G4 1.25 with Tiger OS. Have DV project and media files stored on external Lacie firewire drive. In the middle of editing I get an error message in the Canvas window stating “Display error open and close window….” when I do this and try to open the sequence again it gives me a general error message stating “error: not found” I hit close and behind that window there’s another that says “error, out of memory” Now I know this is wrong because the memory is maxed out and I’ve edited millions of projects like this one and never gotten this error before. I tested the external Lacie on another computer (iBook G4) and it opened the project just fine. I was able to run FCP without getting the same message. Can someone help!!!!
    Curious Jandro
    Alejandro Marin replied 20 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
