Activity › Forums › Apple Final Cut Pro Legacy › fcp rgb issues
fcp rgb issues
Posted by Doug Tessler on February 17, 2009 at 2:17 pmIs there a way to read rgb values in two different clips . In this case just color bars I am trying to match up
How do i adjust the black levels so they are the sameDoug
Doug Tessler replied 17 years, 7 months ago 2 Members · 4 Replies -
Gary Adcock
February 17, 2009 at 3:35 pm[doug tessler] “Is there a way to read rgb values in two different clips . In this case just color bars I am trying to match up
How do i adjust the black levels so they are the same “its called a waveform.
Color allows you to set a ref on one clip and measure that against another.
gary adcock
Studio37
HD & Film Consultation
Post and Production WorkflowsInside look at the IoHD
https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php -
Gary Adcock
February 17, 2009 at 3:36 pm[doug tessler] “Is there a way to read rgb values in two different clips”
Oh forgot one thing
color bars generated in camera are not RGB.
gary adcock
Studio37
Doug Tessler
February 17, 2009 at 4:00 pmYES NOT color bars from a camera these were reference color bars from two sources.
Doug Tessler
February 17, 2009 at 4:04 pmI have two samples to compare, where they’ve been reported to have differing black levels. (one is from us, the other from Anystream Agility; both from same Avid QT reference source.)
i’ve checked for any gamma level settings in the QT files themselves, and they weren’t assigned.
we match a simple QT export (via QT Pro), which isn’t surprising because we use the same QT APIs under the hood.
but, Anystream Agility is somehow matching the original Avid source more accurately, so they must be doing some rescaling or adjustment.
Doug
