Activity Forums Apple Final Cut Pro Legacy FCP Rendering
  • Posted by Timothy Gaer on March 18, 2010 at 7:17 pm
    Hello,
    First I want to thank you guys cause you have all saved me numerous times from a splitting headache trying to figure out how to do things I was not sure of.
    Now on to the problem.
    I need FCP to render faster. I am working on a Mac Pro 2.26 GHZ quad-Core Intel Xeon with 6 GB 1066 MHZ DDR3 ram and 2 Nvidia GeForce GT 120 video cards.
    My problem is I am rendering out a total of 25 30 min broadcast shows to send to numerous different stations and each 30 min show takes approx 2 – 5 hrs (depending on the delivery format ProRes-H.264)
    Is there a hardware upgrade that will cut down the render times? If so what is it… Cost is not to much of an issue I just need to know. Does an AJA or BlackMagic card help with this?
    Also I am Coming out of a system with MPG2 and then converting to Pro Res so I can edit quicker in FCP…. Is there a workflow that will cut or kill that render time? I have been told there are ways to go from an SDI out on a Tricaster into a PRO RES box? Not sure what that is.
    Timothy Gaer
    http://www.timothygaer.com
    https://www.imdb.com/name/nm3014735/
    Everything will be MacTastic
    Robb Harriss replied 16 years, 6 months ago 5 Members · 5 Replies
  • Chris Borjis
    March 18, 2010 at 7:57 pm
    just work in prores on everything.
    export each show then use compressor with virtual clustering turned on
    to convert it to its delivery format.
    that will speed things WAY up.
  • Timothy Gaer
    March 18, 2010 at 7:59 pm
    So there is no hardware solution to this? Most other companies around here are using Black Magic cards and similar things on their machines…..
    Timothy Gaer
  • Michael Gissing
    March 18, 2010 at 8:56 pm
    Firstly if you need to speed up the ProRes final to H264, then export a self contained quicktime which is quick and then use Compressor to do the H264 and enable more cores by setting up a cluster in Qmaster.
    Matrox also make an accelerator for H264. https://www.matrox.com/video/en/products/mac/compresshd/ . I think Elgato also makes an accelerator.
    If you need to go to mpeg2 transport streams then there are many hardware encoders like Tricaster & Tandberg
    https://www.mpeg.org/MPEG/mpeg-related-companies-and-organizations/mpeg-board-or-systems-manufacturers.html
    Expensive but excellent quality and real time.
  • Alan Okey
    March 18, 2010 at 9:11 pm
    [Timothy Gaer] “I have been told there are ways to go from an SDI out on a Tricaster into a PRO RES box? Not sure what that is. “
    Install a video I/O card like an AJA Kona or Blackmagic Decklink. You can then capture a live SDI stream to ProRes in realtime.
  • Robb Harriss
    March 19, 2010 at 1:10 am
    I’m using one of the h.264 turbo HD USB dongles from Elgato for some h.264 renders. It’s been faster than cluster rendering on the MacPro 8 core machines. I’m just using referenced files instead of self contained. I supposed you could double up by using both a queue to the elgato and then another queue to a cluster for rendering.
    Non-linear: all the time and nothing but.
