Activity › Forums › AJA Video Systems › FCP ProRess clips audio distorted
  • FCP ProRess clips audio distorted
    Posted by Marc Colemont on October 12, 2010 at 10:33 am
    I had trouble playing files with sound created in FCP which to be played properly by the Ki Pro.
    In FCP in Apple ProRess defaults, the audio gives a hiss, when you play these files in the Ki Pro.
    Files created for the Ki Pro as two seperate tracks of Mono:
    24-bit Integer (Little Endian), Mono, 48,000 kHz do work.
    Regards,
    Marc Colemont
    Jeremy Garchow replied 15 years, 11 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    October 12, 2010 at 12:12 pm
    As you found out, the audio needs to be dual mono to be played back by the Ki. You are correct.
