Activity Forums Apple Final Cut Pro Legacy FCP Project crashing
  • FCP Project crashing
    Posted by Alison Mcalpine on February 22, 2009 at 10:40 pm
    I am trying to open several old FCP projects however, they all crash. (The projects open; I see all the media and timelines and then the project crashes. I am told: “The application Final Cut Pro has unexpectedly quit”.) I have tried opening various older FCP project files both small and large and the same thing happens. I have tested my FCP program. It works fine. I’ve imported media and created a test file; it works fine.
    So I mailed one of these ‘crashing’ FCP projects to a friend and he was able to open it on his FCP system. However, he has a much higher version of FCP. I am still working on FCP 4.5 because of my old quicktime files. He doesn’t know how to email me back a project file I can use on 4.5.
    Can you suggest a way to solve this problem?
    Kent Stipp replied 17 years, 7 months ago 2 Members · 1 Reply
  • Kent Stipp
    February 23, 2009 at 3:10 pm
    Alison,
    It is my understanding that technically that can be done but Apple does not support backwards compatibility. Is there a specific reason you have not upgraded your QT and FCP?
    your QT files Should still work with newer versions.
    Life Begins at 155mph
    Catch it edit it View it
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
