Activity › Forums › Apple Final Cut Pro Legacy › FCP Plays Out of Sync, but fine in QT
  • FCP Plays Out of Sync, but fine in QT
    Posted by Leslie Kitzinger on May 26, 2009 at 3:56 am
    I captured some 24p mini DV footage. It plays back fine in Quicktime, but when I import into FCP 5, it is considerably out of sync, whether it’s playing from a sequence or in the Viewer. I have tested it on two separate computers with no external monitors attached. I have also used both of these computers extensively and never encountered this problem.
    Any help would you be greatly appreciated!
    Thanks.
    Leslie Kitzinger replied 17 years, 4 months ago 4 Members · 5 Replies
  • David Bogie
    May 26, 2009 at 5:10 pm
    QT Player and the Browser merely display the media. FCP’s canvas displays your media after it has been modified to fit the specification s of the sequence. If your sequence settings do not precisely match the media, there can be sync issues.
    bogiesan
  • Leslie Kitzinger
    May 26, 2009 at 5:17 pm
    It’s out of sync before I even put it in a sequence (playing it in the Viewer, straight out of the Browser). Plus my sequence settings match the clip settings.
  • Dennis Leppell
    May 26, 2009 at 5:21 pm
    Maybe an adjustment to the frame offset in system settings ===>playbackcontrol
  • Tiffany Hauck
    June 1, 2009 at 7:12 pm
    Did you ever figure out a solution to this? I’m experiencing exactly the same problem. I have a project with about 22 clips, all are fine except for two. If I open them in QT, they play perfectly, but are out of sync (and drifting) when I import them into Final Cut, before they even get cut into a sequence.
  • Leslie Kitzinger
    June 1, 2009 at 11:40 pm
    My problem turned out to be that the tape that I thought had been shot 24p was actually 29.97. When I recaptured it at 29.97, it played fine in FCP.
    That doesn’t really sound like your problem though, so good luck!
