Activity Forums Apple Final Cut Pro Legacy FCP playback to monitor
  • FCP playback to monitor
    Posted by Kubrickfan01 on August 30, 2006 at 1:34 am
    Hello all
    Can anyone recommend a reliable card I could buy for playing back a DVCPRO50
    stream to composite/ntsc out in Final Cut Pro Studio? I rented a deck to capture the footage and now need to achieve an ntsc monitor preview.
    I have read about the Fuse-X, heard good and bad.
    Also the Decklink stuff. More pricey, but better support.
    Thoughts?
    Thanks in advance.
    Ben Holmes replied 20 years ago 2 Members · 1 Reply
  • Ben Holmes
    August 30, 2006 at 12:18 pm
    You’d need the decklink pro at $595, so it really depends if that’s worth your while in the longer term – it also doesn’t do analogue ins. Ideally you want Component monitoring if you’re using analogue.
    Decklink and AJA offer the best support and vaule IMHO – and the opinions of most others around here. If you were to get hold of an SD monitor with SDI input, you could get the $295 decklink card and get fantastic monitoring befitting a DV50 stream. Don’t go cheap on the monitoring!
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations.
    “The Supercar Run” now available for international distribution from http://www.electricsky.com
    See you at IBC – we’re there with our FCP/replay truck…
