Activity › Forums › Apple Final Cut Pro Legacy › fcp play, mark, et al, buttons
Posted by Jaenet Guggenheim on December 15, 2008 at 6:41 pmi was starting to edit my project, and it was going fine, i was using viewer properly.
then things changed. i can’t see any buttons below the clip image in the viewer box.
how do i get all those buttons to reappear?
thanks,.
jaenet
John Fishbackreplied 17 years, 9 months ago 3 Members · 4 Replies
John Fishback
December 15, 2008 at 10:33 pmDid the Sequence window (or another) sneak up and cover the buttons?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Jaenet Guggenheim
December 16, 2008 at 1:01 pmwell, no, that bar didn’t cover my buttons. but somehow, they vanished! i find if i select “open clip in new window” the buttons are in THAT window.
the buttons don’t appear in the clip window if i double click on a clip. only if i click on “open clip in new window.” don’t know what i did. wish i could undo it, but just one more blip to deal with.
thanks for writing!
Stace Carter
December 16, 2008 at 2:23 pmHave you tried Ctrl+U, which resets the standard window arrangement?
John Fishback
December 16, 2008 at 2:56 pmHave you trasahed your prefs and repaired permissions?
John
