Activity › Forums › Apple Final Cut Pro Legacy › FCP “Out of Memory” Error
Trevor Ward
July 15, 2014 at 6:07 pmMy suggestion would be to scale them in Photoshop or similar. You can re-size them to just above the resolution of your timeline sequence settings (wither 1920×1080 or 1280×720).
OR, export the sequence as XML and import into Premiere. Premiere handles the large images with no problem.
-Trevor F. Ward
Red Eye Film Co.
http://www.redeyefilmco.com
http://www.MemoriesofGuantanamo.com -
Welyon Sutjipto
January 13, 2015 at 5:44 amAmongst other things that I’ve found to cause this error, sometimes images from clients come from the print domain, and JPEGs could have been set to CMYK color. This will cause FCP7 to just stop rendering and giving you an error message that can be a bitch to figure out.
As much as technology and software is moving ahead, unfortunately a lot of the clients and prod houses that I work for aren’t progressing as fast (institutional level lethargy with regards to investments in new tech) so FCP7 is likely to remain for the next few years to come, at least in this part of the world for me (Singapore).
I’ve started throwing more complex graphics and pictures/stills into Motion 4, which handles these a lot better. It’s not the most reliable software around, but I find where there is FCP7 there is almost always Motion, so i hope it helps someone
Welyon Sutjipto
Director/Editor/Colorist wannabe
youtube.com/welyonsutjipto
