Activity › Forums › Apple Final Cut Pro Legacy › fcp – omf??
fcp – omf??
Posted by Jack Bibbo on June 4, 2009 at 4:49 pmFCP does not IMPORT OMF’s. Anyway to change this? Plugin?
Outside of Consolidating.
Jack Bibbo replied 17 years, 4 months ago 5 Members · 16 Replies -
Aaron Neitz
June 4, 2009 at 4:57 pmI use Soundtrack to import OMF’s and then export stems as aiff back to FCP.
if FCP had native OMF importing that would be a huge timesaver for some of us.
Jack Bibbo
June 4, 2009 at 5:05 pmNo Doubt.
Yeah I was going toward the ST way or just consolidate from the one machine and bring it over.
I have always wondered if there was something outthere.
thanks
Shane Ross
June 4, 2009 at 5:08 pmWow…my post came late. My internet here was wonky and I tried getting that posted for more than a few minutes.
Shane
Read my blog, Little Frog in High Def -
Jamie Pickell
June 4, 2009 at 5:10 pmUse Automatic Duck’s Import OMF plugin. I’ve used it for over 4 years importing both OMFs from Avid and from FCP projects. Works like a champ.
Jamie
Jamie Pickell
June 4, 2009 at 5:13 pmUse Automatic Duck’s Import OMF plugin. I’ve used it for over 4 years importing both OMFs from Avid and from FCP projects. Works like a champ.
Jamie
Aaron Neitz
June 4, 2009 at 5:15 pmAh, there you go. I had forgotten about the Duck! Need to look into that for myself now
Shane Ross
June 4, 2009 at 5:15 pmOMF from what? Avid? ProTools? Then you need Automatic Duck Pro Import:
https://www.automaticduck.com/products/pifcp/
Shane
Jack Bibbo
June 4, 2009 at 5:20 pmAutomatic Duck Import is part of a whole APP. Right. ie. not FREE .
Automatic Duck is great for sure. However I dont have it on these machines where I am currently cutting.
I am just going FCP to FCP. I will probably just consolidate that Specific SEQ and IMPORT in that onto the other machine.
Shane Ross
June 4, 2009 at 5:36 pm[jack Bibbo] “I am just going FCP to FCP. I will probably just consolidate that Specific SEQ and IMPORT in that onto the other machine.”
What are you trying to do exactly? OMF from FCP to FCP? Since FCP cannot import OMFs, I’d recommend against this. But again, what exactly are you trying to do?
Shane
Jeremy Garchow
June 4, 2009 at 5:45 pm[jack Bibbo] “just get my splits out of one FCP machine and into another.”
The simply export a multi track aiff.
