Activity › Forums › Apple Final Cut Pro Legacy › fcp – omf??
  • Jack Bibbo
    June 4, 2009 at 5:51 pm
    just get my splits out of one FCP machine and into another.
  • Jack Bibbo
    June 4, 2009 at 6:12 pm
    Are you saying – FILE/EXPORT/AUDIO TO AIFF(S).
    Because that does not allow me to give mutli-track AIFFs
    Please explain.
  • Jeremy Garchow
    June 4, 2009 at 6:22 pm
    You can export individual stems in FCP by hitting command-zero on your sequence to bring up the sequence settings. Find the audio outputs tab. Set the number of output tracks there.
    Then go back to your audio mixer in FCP. You can then right click on each output track (A1, A2, etc) and choose which output that track gets assigned to. Then File > Export > Aiff and make sure to choose channel grouped. You will than get a separate file for each stem.
    Jeremy
  • Jack Bibbo
    June 4, 2009 at 6:26 pm
    Please explain.
  • Jack Bibbo
    June 4, 2009 at 6:28 pm
    Please explain.
  • Jack Bibbo
    June 4, 2009 at 6:49 pm
    Hey Jeremy, Thanks.
    I really like that.
    However in this case I think that it is going easier to consolidate the SEQ through Media Manager. Then when I bring it over and it is built and i can just move on. It is under 3 min.
    Either way thanks for the tip.
    jack
Page 2 of 2
